Tizen OS based Samsung TV SDK
Aplicatii, update-uri.
smart_jr
Post by smart_jr »
Pentru ca suntem toti pasionati de tehnologie si noutati:
Samsung Electronics announced plans to release Tizen-based
Samsung TV SDK, marking the industry’s first Software Development Kit (SDK) that allows developers to build applications for the Tizen-based TV.
Samsung’s Tizen-based TV SDK Beta will be available early July following the Tizen Developer Conference in San Francisco from June 2–4th. The Tizen-based Samsung TV SDK Beta supports the HTML5 standard through its framework called Caph and enables developers to write apps that run on a Tizen OS –based TVs.
“We are excited to offer app developers the opportunity to experience this new platform in advance with the release of Beta SDK,” said YoungKi Byun, Vice President of Visual Display Business S/W R&D Team, Samsung Electronics. “With the ultimate goal of expanding the TV ecosystem for apps, we will continue our efforts to provide innovative functions and improve the development environment.”
Samsung’s new SDK marks the industry’s first attempt at significantly improving the development ecosystem by offering new technologies such as an interface for virtual TV apps development. Developers can now virtually see all necessary TV functions without a physical TV. Developers can also remotely modify code on their PCs with the new debugging feature, whereas in the past they had to connect directly to the TV’s software to correct application errors.
With increasingly sophisticated animation effects and designs, the Tizen-based Samsung TV SDK Beta also features various scenarios including Smart Interaction, allowing users to control their TVs with simple hand gestures and voice commands; and multi-screen, which can be used to link a TV with various devices including mobile and wearable gadgets.
The launch of Tizen-based Samsung TV SDK represents another step in Samsung’s larger efforts to encourage innovation in the developer community and enable full flexibility in UX design. Samsung will continue to actively work with Tizen to enable developers and operators to extend their reach to other connected devices.
Samsung’s Tizen-based TV SDK can be downloaded at the Samsung Developers Forum website, http://www.samsungdforum.com, starting in early July, 2014.
Samsung Smart TV
- See more at:
http://global.samsungtomorrow.com/?p=37 ... m/?p=37125
Re: Tizen OS based Samsung TV SDK
In prima faza m-am uitat CE ESTE TIZEN OS? Apoi ma gandesc ca este o "replica" la Web OS-ul de pe LG, care momentan este un "prunc" in toata regula. Smart HUB-ul de pe Samsung este lux in comparatie cu ce este acum in WebOS. Apoi Web OS a fost un esec si s-au gandit cei de la LG sa-l "adopte". Banuiesc ca cei de la Samsung au cautat si ei ceva open-source.
LE:
- Tizen is an open and flexible operating system
- The current Tizen profiles are Tizen IVI (in-vehicle infotainment), Tizen Mobile, Tizen TV...
- The Tizen project resides within the Linux Foundation and is governed by a Technical Steering Group.
Chestia asta ar descuraja actualii publisheri de aplicatii in Smart... Poate.
smart_jr
Post by smart_jr »
Partea buna este ca apun developeri pot creea aplicatii si sa le emuleze pe softul oferit de Samsung, fara a fi necesara posesia unui Tv Samsung.
E ceva gen simulator TV.
Eu unul ma astept la o crestere a numarului de aplicatii. Cel putin peste cativa ani :D
ares_geo
Post by ares_geo »
salut,
Tizen este alternativa la android pe care o dezvolta Samsung si Intel - pentru a reduce dependenta de Android.
Vis-a-vi de ce stie sa faca...cred ca o comparatie mai apropiata poate fi facuta intre TIZEN si Bada (prima incercare Samsung de a face un sistem de operare).
Vis-a-vi de WebOS - este cumparat de LG de la HP si este sistemul care a fost pe PALM-uri...si din pct meu de vedere un sistem superior insa implementat foarte foarte prost.
Legat de dezvoltarea de aplicatii pentru Smart TV-urile Samsung...sunt destul de usor de dezvoltat. De ce :
- exista intr-adevar SDK ce poate fi downloadat (emulator) : http://samsungdforum.com/Devtools/SdkDownload
- acum exista SDK si pentru TIZEN : http://samsungdforum.com/TizenDevtools/SdkDownload
- exista si Remote Test System : https://www.samsungdforum.com/RTS/Front/Main
Tehnologia din spatele aplicatiilor este foarte accesibila -> HTML5 si JavaScript : http://samsungdforum.com/Devtools/Spec
De asemenea exista foarte multa documentatie in ceea ce priveste dezvoltarea aplicatiilor.
ares_geo wrote:Vis-a-vi de WebOS - este cumparat de LG de la HP si este sistemul care a fost pe PALM-uri...si din pct meu de vedere un sistem superior insa implementat foarte foarte prost.
Implementat prost de LG?
ares_geo
Post by ares_geo »
Da, implementat prost.
Ca si sistem de operare, este flexibil, versatil, responsiv si foarte si foarte adaptabil platformei pe care este pus sa ruleze.
Ceea ce ruleaza acum pe LG-uri, este o versiune "light" a WebOs-ului, ciuntit pe ici si pe colo, astfel incat sa ruleze decent.
