HI,
One for all you knowledgeable techie peeps...I've searched and searched but can't find a solution.Samsung LED TV: watching cookery shows, when something is frying the sound goes haywire - the hiss of the frying goes really loud, drowning out the voice. Same sometimes happens if there's a rainy scene, the sound of the rain goes loud (to the point of distortion) and voices can't be heard over it.Seems like some sort of "smart" auto adjustment/compensation (that's got it wrong!) - it's always done it, but I can't find any setting that may be causing this. Anyone else noticed this / got a solution?
Please help.
I did not find the right solution from the internet.
Thanks!
Samsung TV sound issue - Clear voice
Re: Samsung TV sound issue
There is an option called "Clear voice" in Sound settings. It's possible to solve your problem. Or just change sound mode.
