Main characteristics
Type: LCD TV;
Diagonal: 55" (140 cm);
Display format: 16:9;
Resolution: 1920x1080;
Support HD: 1080p Full HD;
LED light: yes;
Stereo sound: yes;
Refresh rate: 600 Hz;
3D support: yes, packing technology, the conversion of 2D to 3D;
Internet access (Smart TV): yes;
Progressive scan: yes;
Signal reception
Support stereo sound NICAM: yes;
Support TV standards: PAL, SECAM, NTSC;
Support DVB-T: DVB-T MPEG4;
Support DVB-C: DVB-C MPEG4;
Support DVB-S2: yes;
Teletext: yes;
Supported input formats: 480i, 480p, 576i, 576p, 720p, 1080i, 1080p;
Permits available when connected to a PC: 640x480, 800x600, 1024x768, 1280x1024, 1360x768, 1920x1080;
Sound
Sound power: 20 W (2x10 W);
Acoustic system: two speakers;
Surround sound: yes;
Dolby Digital Decoder: yes;
Multimedia
Supported formats: MP3, WMA, MPEG4, DivX, MKV, JPEG;
Interfaces
Inputs: AV, component, SCART, RGB, HDMI x4, USB x3, Ethernet (RJ-45), Wi-Fi;
Outputs: optical;
Headphone Jack: yes;
Slot for CI/PCMCIA: yes;
Functions
Picture in picture: yes;
Support 24p True Cinema: yes;
DLNA support: yes;
Video recording: on USB drive;
TimeShift Function: yes;
Supports Skype: yes;
Sleep timer: yes;
Protection of children: yes;
Management: voice;
Additionally
Color: black panel with a basis;
Wall mountable: yes;
Kensington Lock: yes;
Dimensions with stand (WxHxD): 1234x790x307 mm;
Weight with stand: 18 kg;
Dimensions without stand (WxHxD): 1234x708x47 mm;
Weight without stand: 16.4 kg;
Additional information: CMR 600; 2 pairs of glasses included; WiFi Direct; IR input;
Samsung Smart TV UE55F6640 - Pareri
Re: Samsung Smart TV UE55F6640
Ai ce testa
am vazut ieri cateva filme online ,am iesit si am intrat cand am vrut in ele,nu s-a interrupt nu nimic merge perfect,as vrea totusi sa imi iau si acea camera web ca am inteles ca am sa pot folosi motion control daca o am.
