Eroare Samsung Link - ReferenceError: $ is not defined
styng
Post by styng »
Azi am obervat ca programul imi da o eroare cand accesez: "Nearby device connection setting" si nu pot modifica nimic (fisierele cu filme ce vreau sa le vad pe TV)
Precizez ca am reinstalat programul fara nici un rezultat.
Ma poate ajuta careva? :/
busterv1
Re: Eroare Samsung Link - ReferenceError: $ is not defined
Post by busterv1 »
Hello
i Had the same problem took me very long time to work out .
what i did to fix this refernceerror:$ not defined is following
on your pc uninstall samsung link and delete any sub folders you can find .
THEN FOLLOW these steps
1)network and sharing center
2)make sure you joined homegroup ( if not create a homegroup private)
3)then on the network and sharing page click( homegroup bottom left of page)
4)now you should be on change homegroup settings page
5)click ( change what youre sharing with this homegroup)
6)then make sure pictures,videos,music,printers and devices all shared.
7)then click next and finished
8) now click ( allow all devices on this network such as tvs and game consoles to play on my shared content )
9) now allow all on local network ten click next , next , and finish.
Now re install samsung link and during setup make sure location is c:/programs x86
once installed click samsung link -- nearby device connection settings and your reference error will be gone
take care
busterv1 wrote:Now re install samsung link and during setup make sure location is c:/programs x86
I assume this is corect only for pc with windows x64... and it's c:\Program Files x86
Thanks for your message.
