Buna.
Aici voi posta release note-urile pentru modelele pe care vreti voi sa stiti ce s-a modificat in urma unui update de soft.
Daca doriti release note-ul pentru un model anume, postati modelul aici si in scurt timp va fac upload la fisier.
LED - Seria ES (toate marimile)
ES6100 - http://www40.zippyshare.com/v/84937458/file.html
Release Log - Software update - Ce s-a modificat
Re: Release Log - Software update - Ce s-a modificat
Se pare ca fisierul original nu se poate deschide pentru ca se encripteaza. (Securitate impotriva divulgarii informatiilor)
Asa ca voi posta numai ce s-a schimbat in ultima versiune.
Ar fi bine daca mi-as putea modifica acelasi post tot timpul ca sa nu creez atatea posturi.
LED EH/ES 4000/5000/6000, PDP 550/570
Fixes from 1031.0 to 1032.0
Power Off/On problem caused by ARC Count
Suddenly Playing is ended using Smooth Streaming funtion.
Remote Protocol IP, MAC Size Crash Problem
DMR 2012 - removed MicrosoftElement pnpx:X_compatibleId from DMR's device description
Youtube 3D Video is not supported.
Improve XFS FileSystem Repair Tool
Fix Buffer Flow attack
Fix ORS(Austria), Astra 19.2 Service List Name Parsing Bug
"There is video freezing after playing for 2 hours. HTTP 412 Errors come out repeatedly."
Use Secure storage for authentication instead of file. Update authentication.
Add HLS+Verimatrix Function for Magyar Telecom
Salut. Spune-mi si mie, te rog, pentru 40D5700 & 37ES5700. Merci
Pentru 37ES5700 este acelasi soft cu care l-am postat mai sus LED EH/ES 4000/5000/6000, PDP 550/570essco wrote:Salut. Spune-mi si mie, te rog, pentru 40D5700 & 37ES5700. Merci
Softul 1032.0 se foloseste la toate acele modele.
UE405700
Fixes from 1021.1 to 1022
(SDAL-5.43.0.0) Seamless mode interlace dynamic scaling. For SEC request, disable dynamic scaling in interlaced input.
(AP_SmartHub) SmartHub Update - MAC address conflict fix
(AP_FlashPlayer) YouTube On TV - TV Latch-Up while watching YouTube. Memory and buffer size management fix.
(SDAL-5.43.0.0) Netflix, MLB 1/2, 1/4 - post scaling up ratio is incorrect because the calculation of prescaling size of H and V is incorrect. Refined the calculation method in firmware.
(BP-App/DTP-BP-0617-32) [MHEG] Press ‘Guide’ to enter the native guide -> audio but no video - The problem is caused by unnecessary code by broadcasters. The compare code above is change to ignore the component tag.
Stores the boot/default video component data that is later checked for change in mhvBroadcastStream’s startVideo code.
[HBBTV] France application return key latch up (2011 genoaP)
YouTube 3D - 3D Volume Bar OSD fix
[Maple][2011/2010] HTTP (Maxdome )
BT Vision - SSL Mutual Authentication
BBC Sports , video. - The if condition is fail so the FW will enter DTV mode and do the "Force interlace" command. FW will always report this file is interlace. The stream is Dynamic scaling stream. So the webapp can't play the file.
Correct the checking condition.
Auto Subtitle On
Full Red 1 Pixel Garbage. - Before convert to RGB data format, data must pass the 422 to 444 filter. The boundary pixel when pass 422 to 444 filter, we refer to the garbage data out of boundary. So make the boundary data error.
Enable 422 to 444 filter boundary protection function.
Mp3 audio - Parameter width used to store decoded frame count in mp3 decoder doesn’t match report register width used to report to MCU, and makes waiting condition for both dsp and MCU. Unify DSP parameter and register report to MCU
Nu neg bunele tale intentii, insa am o ezitare cu privire la divulgarea unor informatii pentru care Samsung le considera confidentiale. Nu stiu care-i motivul "secretizarii" acestui log si nu publica ei ceea ce ai pus tu aici.johnnydj wrote:Securitate impotriva divulgarii informatiilor
POATE ca, ar fi o solutie sa exprimi aceste modificari ca si constatari proprii.
Orice comentariu adaugat se poate modifica in urmatoarele 15 minute. Blocarea posibilitatii editarii permanente a mesajelor isi are rostul ei. Sper sa intelegeti...johnnydj wrote:Ar fi bine daca mi-as putea modifica acelasi post tot timpul ca sa nu creez atatea posturi.
Ca si solutie ar fi sa iti dau drepturi de moderare pe un forum anume. Vedem...
Momentan, intrebarea mea este daca Samsung poate trage la raspundere acest forum pentru divulgarea de informatii confidentiale?
Salut, ma gandesc ca de aceea sunt informatii confidentiale deoarece fisierele care contin aceste date, contin si bucati de cod sursa, unde se arata cum a fost si in ce a fost modificat.
Insa eu ce am postat, este doar care a fost problema gasita, cum se manifesta si cum s-a remediat. Fara codurile sursa
Ok, nu as vrea sa-i suparam pe cei de la Samsung
sa ne sara in cap cu drepturile de autor.
Nu stiu de ce nu publica ei un log ca suntem multi care am vrea sa stim.
De ex. mi se pare interesanta "(AP_FlashPlayer) YouTube On TV - TV Latch-Up while watching YouTube. Memory and buffer size management fix." chestia asta, pentru ca-mi suna ca si cum clipurile de pe VPLAY sau Youtube nu ar mai da acel reset aiurea.
Pe de alta parte, daca chiar o sa avem acces la aceste loguri, le vom organiza, cei interesati sa nu caute intre zeci de comentarii ce-i intereseaza, deci le vom edita.
PS: am sters quote-ul pentru ca nu este necesar ca raspuns al unui comentariu imediat anterior. Ms de intelegere.
de aceea m-am gandit ca ar fi bine sa pot edita un singur post.
sau ceva de genul.
sau ceva de genul.
Pentru UE32EH6030 ce sa modificat de la 1012 la 1013. Multam
Salut, este aceeasi modificare care am postat-o la LED EH/ES 4000/5000/6000, PDP 550/570
Pentru ca toate modelele din seria 4000 5000 6000 folosesc acelasi soft.
