Moderator: danyelsan
Stie cineva cum pot da share pe ftp unui user doar la un folder din folderul \video? Din cate vad pot da share doar intregului folder \video.
A aparut si tutorial pentru instalarea Plex Media Server: http://forum.nas-central.org/viewtopic.php?f=249&t=7603
De ce imi apar evenimente in log? NSA-ul este deschis mereu dar nimeni nu a umblat la el in momentele alea (dupa cum vedeti chiar si noaptea sau dimineata la 5...).
E posibil sa pice routerul sau netul de la Romtelecom la momentele alea?
Eu am setat debifat serverul FTP si totusi vad ca imi apare ca a schimbat portul, etc. Nu inteleg.
1 2013-02-12 13:51:20 user info User admin has logged in from Web!
2 2013-02-12 13:07:03 system info NTP updates successfully from ntp.nasa.gov
3 2013-02-12 13:07:02 built-in-service info Auto daylight saving setting: SUCCESS
4 2013-02-12 05:10:29 built-in-service info FTP port has changed to 21
5 2013-02-12 05:10:28 system notice Hostname is set to ZYXEL.
6 2013-02-12 05:10:27 system info NTP updates successfully from ntp.nasa.gov
7 2013-02-12 05:10:27 built-in-service info Auto daylight saving setting: SUCCESS
8 2013-02-12 05:10:27 built-in-service notice The NTP service is enabled
9 2013-02-12 05:10:26 built-in-service info Clock timezone is set to GMT+0200
10 2013-02-12 05:10:26 built-in-service notice NTP server is set to 'ntp.nasa.gov'
11 2013-02-12 05:10:26 interface notice Network port is disabled
12 2013-02-12 05:10:26 interface notice Network Config setting is changed
13 2013-02-12 05:10:24 system notice DNS server setting is changed
14 2013-02-12 05:10:15 built-in-service notice FTP server stops
15 2013-02-12 01:07:01 system info NTP updates successfully from ntp.nasa.gov
16 2013-02-12 01:07:01 built-in-service info Auto daylight saving setting: SUCCESS
17 2013-02-11 21:43:10 built-in-service info FTP port has changed to 21
18 2013-02-11 21:43:09 system notice Hostname is set to ZYXEL.
19 2013-02-11 21:43:08 system info NTP updates successfully from ntp.nasa.gov
20 2013-02-11 21:43:08 built-in-service info Auto daylight saving setting: SUCCESS
21 2013-02-11 21:43:08 built-in-service notice The NTP service is enabled
22 2013-02-11 21:43:08 built-in-service info Clock timezone is set to GMT+0200
23 2013-02-11 21:43:08 built-in-service notice NTP server is set to 'ntp.nasa.gov'
24 2013-02-11 21:43:07 interface notice Network port is disabled
25 2013-02-11 21:43:07 interface notice Network Config setting is changed
26 2013-02-11 21:43:05 system notice DNS server setting is changed
27 2013-02-11 21:42:56 built-in-service notice FTP server stops
Instaleaza MiniDLNA si nu o sa mai ai probleme cu mkv-uri , o sa ai optiune de Forw. si Re. (poate merge si cu Twonky , insa pornesti filmul apoi apesi pe tools de la telecomanda si de acolo poti derula ) .lauryca wrote:Cu Twonky pot da pauza si stop la un film (forward si rewind nu se poate), incarca subtitarea externa la mkv-uri (si bluray remux si mkv simpu 1080p) si imi afiseaza structura directoarelor. Pentru ca mkv-urile sa fie rulate trebuie ca Media Rceiver Type - Samsung Smart TV(am atasat o captura); fara aceasta setare nu rula deloc mkv-uri. Mai testez si pe urma vad daca mai instalez miniDnla.
Oricum nu se compana MiniDLNA cu Twonky ala !
Il bag in teste perioada urmatoare si daca este ok o sa ii fac tutorial in romana !lauryca wrote:A aparut si tutorial pentru instalarea Plex Media Server: http://forum.nas-central.org/viewtopic.php?f=249&t=7603
Este pe primul loc intr-un clasament ( chiar daca este pt PC insa pare a fi bun server-ul ) : http://lifehacker.com/5975362/five-best ... ia-servers
L.E. : Foarte bun PLEX , deja i-am facut si tutorial : http://samsungtv.ro/topic1228.html
Thom Yorke
Ieri am comandat un D-link DNS315 si dupa ce m-am chinuit cu el cateva ore bune, nu am reusit sa fac functional streamingul catre un Samsung UE40EH5450.
Am citit 1000 de pagini pe net si am aflat ca este cumva imposibil.
Acum am citit acest thread aproape in intregime si am vazut plusuri si minusuri legate de acest NSA310 pe care intentionez sa il comand.
Intrebarile care raman si pe care vi le adresez sunt: Poate acest NSA310 sa functioneze ca server DLNA cu un TV Samsung? S-au rezolvat problemele legate de subtitrari? Este ceva ce ar trebui sa stiu inainte de a face comanda, pentru a nu pati ce am patit cu cel de la D-link?
Va multumesc anticipat pentru raspunsuri.
Salut. Eu doar atat pot sa ma pronunt: cat l-am incercat, pe Samsung l-am incercat. Ziceam atunci ca a rulat si MKV din bluray remuxat, deci un fisier de ~30 GB. Apoi au venit colegii de forum "puternic" si au completat subiectul NSA310 cu tutoriale si discutiile pe care le-ai citit. Din ce vad eu este necesar sa instalezi un client de torente calumea pe el, la fel si un miniDLNA, PLEX, etc. Diferenta fata de "experienta" ta anterioara este ca aici se poate... se mai poate instala una alta. Cu subtitrarea am ramas si eu mai asa... in dilema ca nu am inteles daca ia sau nu fisierul extern, unii "Da", altii "Nu"...
Este oricum cea mai buna varianta DUPA Synology.
Buna!
Nu reusesc sa fac tv-ul samsung es550 (ultimul firmware, luat de pe samsung.ro) sa vada zyxel nas310 (ultimul firmware, 4.50, twonky 7.0.9) din acelasi LAN. Pur si simplu nu-mi apare in lista de surse, desi:
- televizorul vede un server twonky instalat pe calculator
- 2 clienti de dlna pt iOS vad serverul de pe zyxel nas310 fara probleme
S-a mai lovit cineva de problema? S-a rezolvat cumva?
Multumesc,
Cristian.
Multumesc,
Cristian.
Sper sa nu incalc vreo regula a formului [daca da, rog editare din parte admin] urcand un link catre un alt site. Am descoperit recent un review video, in romana, al NSA320, care mi se pare extrem de util in special pentru cei care sunt inca in categoria indecisilor (unde ma aflu si eu,
). http://www.videotutorial.ro/?p=10482 . Autorul promite ca revine si cu tutoriale explicite legate de aplicatiile instalate pe acest NSA.
Desi nu am urmarit topicul, complet... sunt in fata unei mari dileme. Imi doresc de la un NAS sa aibe 2 bay-uri (in care sa pun 2 HDD de 500GB pe care le am deja, in RAID 1, pentru protectia datelor personale, si sa nu mai stea in PC), sa aibe 1xUSB 3.0 pentru ca mi-am achizitionat WD-ul de 2TB (la recomandarea chiar din reviewul de pe acest site), sa fie capabil, in adevaratul sens al cuvantului de a fi un media server (adica sa poata citi iso blu-ray, sa poata reda fara probleme remuxuri si blu-ray-uri la 1080, inclusiv cele 3D <<asta nu cred ca o voi reusi decat cu un media player dedicat>>, si in special sa-mi ia subtitrarea fie ea externa sau interna de la orice combinatie de format de film). NSA325 se apropie de ce vreau, dar nu stiu cat e de potent procesorul, DS213 ar fi fost ok daca nu ar fi single core, DS213+ este dual core, dar e un procesor atipic si nu stiu cum sta cu suportul si cu rularea aplicatiilor, DS212+ la fel cu procesorul iar memoria e pe 16 biti... in final doar DS412+ pare sa aibe tot ce vreau (chiar daca are 4 bay-uri)..dar e de 3-4 ori mai scump decat ZyXEL ... mare dilema am!
Cristian, verifica in admin-ul NSA-ului daca e bifat Eneble la Aplication -> Media Server -> Home Screen and DLNA/UPnP Media Players.
@ramadri, la ce vrei sa-l folosesti? Depinde de aplicatiile pe care ti le doresti sa ruleze pe el. Daca stii ca vei avea mai multe procese de rulat, mai bine uita-te la memoria RAM. Sunt solutii Synology care iti permit inclusiv marirea memoriei, daca nu esti multumit.
@sabba: optiunea din meniu de care zici exista in firmware-ul 4.4x. Ultima versiune de firmware (la care am trecut imediat ce am despachetat cutia), 5.50, are o versiune noua de twonky, a carui configurare se face pe portul 9001.
