Standardul Wifi n-are nici în clin nici în mânecă cu ideea de compatibilitate între echipamente, iar aplicația lor folosește Wifi-ul. Altfel spus, individul de la Samsung doar a eschivat, ca un incompetent ce este.
Pentru că pe toți v-am văzut cuprinși de febra testelor, dar și pentru că mai există persoane ce vor să-și testeze TV-ul la sau înainte de achiziție, v-am urcat pe MEGA colecția mea de teste. Folderul MP4-2c conține teste pentru calibrarea TV-ului. Manualul pentru a le înțelege îl luați de aici: http://redirect.viglink.com/?format=go& ... L%20(.pdf)
Link download teste: https://mega.nz/#!wJNnzT4B!omXE3SOEgyJq ... _KrkFodi9w
Se referea la compatibilitatea ScreenMirroring, care din pacate, are multe incompatibilitati.
Hi, According to Samsung KU60xx series product info and adverts, there should be green "Games" tab in Smart Hub (Tizer). I didn't find games on my UE50KU6092U.
Do someone of you have games on TV?
Unfortunatelly, no. As far as I read, only UK versions do have Games tab in Smart hub. There was somwhere (don't remember where right now) a way to modify the coutry in Service menu, but still I don't know if it solve the "problem".
sammy screen mirroring e tot un soi de standard. Singurele cerinte sunt cele de sistem, respectiv minim Android 4.2.2, altfel nu merge.
I've already tried to change region to UK, but this added only another list of pre-installed apps, which anyway could be added from apps list. Thats bad, cbecause tehre was dilema to buy Samsung or some Android TV.
OK, then I believe the only way to clarify the problem is to contact Samsung.
PS: the change of country/region should be made in firmware via Service menu, but I didn't reccomend you, unless you're an expert.
. Where are you from?
I'm from Latvia. I've called local Samsung support but they couldn't comment on which exactly models or regions Games are available. and the most annoying answer was "What do you expected, this is new model, so firmware could be changed / modified in future. Just wait, maybe Games will be added someday, or not". After that I don't want to call them again. They also offered to remotely connect to my TV, on working day, working time and make "the big reset", but they do not give any chance that it could add this feature. Anyway I'm not at home on working time, so it's nearly impossible.
Nice to meet you on a Romanian forum.
Indeed, it's a new model and luckily the Samsung firmware support is above average. I suppose we only can wait that they keep their promise, if it was a promise.
what firmware version u have ?
Hello,selector wrote:Hi, According to Samsung KU60xx series product info and adverts, there should be green "Games" tab in Smart Hub (Tizer). I didn't find games on my UE50KU6092U.
try this: https://www.youtube.com/watch?v=wlsh3_e42sA
or this: https://www.youtube.com/watch?v=bx1t7chaeSw
