DUAL SCREEN MONITOR ISSUES
Cu sau fara tuner. Monitoarele cu tuner pot fi considerate televizoare, avand in vedere DVB-C-ul integrat, chiar si player (porturi USB)
Mesajde spadekevin » 01 Aug 2018, 14:18
Hi,
I seem to be having some issues running ArchiCAD 12 with 2 monitors.I have a MacBook Pro (2.4 GHz Intel Core 2 Duo, 4 GB RAM, GeForce 8600M 256MB vram).When I am hard at work at my desk, I have the system connected to 2 monitors to enlarge my virtual workspace. I place my Project Navigator and other tool palettes on the second monitor. Works great.When I'm working elsewhere, away from my desk, or I otherwise do not have access to that second monitor, ArchiCAD does not appear to be smart enough to realize there's only 1 screen, and my palettes are all gone. Toggling them on and off doesn't bring them up. Restarting ArchiCAD doesn't help. (Typically, ArchiCAD isn't running when I unplug the external monitor.) The palettes are obviously still on that 2nd monitor, despite the fact that its no longer connected.This also happens with the pop-up (for dragging, etc) as well as the tracker.New windows (views and layouts) will reposition themselves, although the aspect ratio is per the monitor they were last on.Any ideas? Glitch in the program, or is there a way to reset to default positions for all the palettes?
Please help.
I didn't find the right solution from the Internet.
References:-
https://archicad-talk.graphisoft.com/vi ... hp?t=29488
2d Motion Graphic
Thanks!
spadekevin
Înapoi la Monitoare
ATENTIE
Noile modele 2018!
PROMOTIE
Click aici pentru detalii!
