Software Problem
Software Problem
Mesajde spadekevin » 01 Aug 2018, 14:17
Hi,
I just got an Up! printer and I can not seem to get the drivers to properly install on my computer. I downloaded and installed 1.16 and I am running Vista in 32 bit. Everything seems to go normally, but after the driver install it tells me I need to restart. After restarting, it goes through the process again, then once again tells me to restart. The driver never seems to install, and if I run the Up! software it immediately crashes.Just to try and get something to run, I downloaded 1.09 and it installed the driver and ran fine. I could initialize the printer from the software and it seemed to communicate properly. Someone tell me what I am doing wrong so that I can use current software.
Please help.
I didn't find the right solution from the Internet.
References:-
https://www.tiertime.com/forum/viewtopic.php?t=1064
Video Intro Graphics
Thanks!
spadekevin
Înapoi la Software
ATENTIE
Noile modele 2018!
PROMOTIE
Click aici pentru detalii!
