Nvidia GT 720M pentrut filme 3D prin HDMI
Prezentări diverse și discuții cu referire la gadgeturi.
Mesajde samsung » 01 Iun 2014, 17:28
Salut !
Vreau sa imi schimb vechiul laptop care nu are HDMI cu unu nou cu placa video Nvidia GT 720M care are hdmi, vreau sa il conectez prin HDMI la un Samsung 40F6400 3D pt a vizualiza filme 3D cu subtitrari 3D !
Ce parere aveti, face placa video fata sa imi dea semnal Full Hd 3D cu sunt DTS 5+1 in TV-ul mentionat mai sus ? Vreau sa vad filme ISO Blu-Ray si mkv-uri
Samsung 3D 40F6400
samsung
Re: Nvidia GT 720M pentrut filme 3D prin HDMI
Mesajde sammy » 01 Iun 2014, 17:47
Conteaza si procesorul... sistemul per ansamblu. Ultima data ca ma interesau placile video citisem de cele cu hardware dedicat bluray...
Am sa mut acest topic.
Mesajde samsung » 01 Iun 2014, 19:01
Leptopul e un asus !
-8 GB RAM DDR3
-Pocesor I3 (4x1,8 Ghz)
-Placa video Nvidia GT 720M 2GB Ram
Pe site-ul placi video la Features spune asa :
HDMI and Blu-Ray 3D support
Support for HDMI output enables sending both high-definition video and audio signals to an HDTV via a single cable. Connect your laptop to any 3D enabled TV with NVIDIA 3D TV Play and stream all your 3D content onto the big screen, including Blu-Ray, 3D photos, even your games!
Dual-link DVI Support
Able to drive industry’s largest and highest resolution flat-panel displays up to 2560x1600 and with support for High-bandwidth Digital Content Protection (HDCP).
High-Definition Audio Bitstreaming
Full-support for high-definition audio bitstreaming, including Dolby TrueHD and DTS-HD formats.
Hardware Video Decode Acceleration.3
The combination of high-definition video decode acceleration and post-processing that delivers stutter-free video, stunning picture clarity, accurate color, and precise image scaling for movies and video all with incredible energy efficiency.
3 - Supported video software is required to experience certain features. Visit www.nvidia.com for more details.
Samsung 3D 40F6400
samsung
Mesajde chiciuc » 02 Iun 2014, 12:07
am vazut un film 3d SD pe un amarat de Celeron M 2 GHz, placa video Intel GMA 4500 Integrated Graphics, iesire VGA. :lol:
Coeficient: 162 (votes: 237)
Mesajde sammy » 02 Iun 2014, 12:46
Fisier MKV?
Ce player soft?
Cu ceva vreme in urma umblam dupa soft care sa lucreze cu 2 nuclee la decodare MKV pentru ca mergea in reluare.
Mesajde chiciuc » 02 Iun 2014, 13:22
filmul a fost:
Percy Jackson: Sea of Monsters 3D 2013 1080p BluRay Half SBS DTS
File Extension: MKV
Audio Language: Portuguese / English
Subtitles: Portuguese
Video Quality: Bluray - 3D
Release Year: 2013
Video codec: H.264 / AVC
Audio Codec: AC3/DTS
Resolution: 1920 x 1080 Pixels
Player: kmplayer
Ochelari: de aia din reviste.
Înapoi la Diverse recenzii / Alte echipamente IT
