Home Theatre Samsung HT-E5550 Review
Mesajde sebastian091074 » 09 Noi 2012, 15:49
Despachetare:
Home_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_01.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_02.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_03.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_04.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_05.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_06.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_07.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_08.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_09.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_10.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_11.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_12.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_13.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_14.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_15.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_16.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_17.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_18.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_19.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_20.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_21.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_22.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_23.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_24.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_25.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_26.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_27.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_28.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_29.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_30.JPGHome_Cinema_HT-E5550_Review_Pret_Home_Cinema_HT-E5550_31.JPG
VEZI PRET
46ES6100, 22D5003, Home Cinema HT-E5550, SG SII, SG NOTE 4
sebastian091074
Moderator
Coeficient: 21 (votes: 27)
Localitate: Constanta
Re: Home Theatre Samsung HT-E5550 Review
Mesajde danny95fs » 09 Dec 2012, 09:19
sunt interesat si eu de acest sistem( de fapt vreau sa schimb vechiul sistem, pt a lua unul cu intrare optica) daca se poate ceva pareri!
multumesc anticipat!
ue40d6530
danny95fs
Mesajde axx3l » 10 Dec 2012, 19:43
Salut. Boxele din fata se pot monta pe perete? Nu am vazut sistemul de prindere atunci cand ai filmat unboxing-ul
axx3l
Mesajde sebastian091074 » 10 Dec 2012, 22:21
inca nu am reusit sa descopar ceea ce poate face acest sistem...am un bebel mic care a ocupat camera unde se afla sistemul :) ...am sa-l rog pe tibi sa puna si pozele pe care le-am trimis cu acest sistem...detalii mai amanuntite se pot afla de pe site-ul samsung la modelul respectiv are trecut acolo manualul de utilizare de unde te poti inspira daca este ceea ce cauti...
in functie de cum pot butona, testa ceva la el o sa afisez pe forum...
axx3l boxele din fata cat si cele din spate pot fi montate pe perete, ele sunt formate din 2 jumatati si o talpa...jumatatila de deasupra pot fi desfacute si atasate pe perete...
de retinut :
Selectarea poziţiei de audiţie
Poziţia de audiţie trebuie să fie la
o distanţă de aproximativ 2,5-3
ori mai mare decât diagonala
televizorului. De exemplu, dacă
aveţi un televizor cu diagonala de
116 cm, amplasaţi poziţia de audiţie
între 2,92 şi 3,50 metrii de ecran.
Boxele frontale
Aşezaţi boxele în faţa poziţiei dvs. de audiţie, orientate spre dvs. (la aproximativ 45°).
Aşezaţi boxele frontale astfel încât tweeterele acestora să fie la nivelul urechii dvs. Aliniaţi
partea din faţă a boxelor frontale cu partea din faţă a boxei centrale sau aşezaţi-le uşor
în faţa boxelor centrale.
Boxă centrală
Este recomandat să instalaţi boxa centrală la aceeaşi înălţime cu boxele frontale.
O puteţi aşeza pe televizor sau sub acesta.
Boxele surround
Poziţionaţi aceste boxe în părţile laterale faţă de poziţia de audiţie. Dacă nu există
suficient spaţiu, aşezaţi boxele faţă în faţă. Aşezaţi-le la o distanţă de aproximativ
60-90 cm deasupra nivelului urechilor, orientate uşor în jos.
* Spre deosebire de boxele frontală şi centrală, boxele surround sunt utilizate în
principal pentru efectele sonore. Sunetul nu se va auzi în toate.
Subwoofer Poziţia subwoofer-ului nu este foarte importantă. Îl puteţi aşeza oriunde doriţi.
sebastian091074
Moderator
Mesajde sammy » 10 Dec 2012, 23:33
Scuzati intarzierea postarii pozelor, sebi mi le-a trimis demult... Lipsa de timp isi spune cuvantul :oops:
Mesajde gigi43 » 12 Dec 2012, 11:18
Stabilirea nivelului boxelor audio & Distanță într-un sistem de sunet surround
Reglarea întârziere între difuzoarele frontale și din spate este importantă atunci când calibrarea sistemului dumneavoastră. Setarea întârziere prea mult timp poate duce la o ecou, ​​domeniul nefiresc de surround, sau poate provoca schimbări imagistice în sunet de. Cu toate acestea, ajustarea întârziere prea scurt poate duce într-un câmp de sunet plat 2-dimensionale între difuzoarele frontale și din spate.
Luați în considerare următoarele:
Viteza sunetului în aer este: 1100 ft / sec
1100 (ft / sec) * 1 (sec/10 ^ 3 ms) = 1,1 ft
Fiecare ban 1 de întârziere adăugate corespunde la 1,1 metri distanta de creștere a difuzoarelor spate în raport cu poziția dvs. de ascultare.
De exemplu: Setarea întârzierea spate la 25ms ar rezulta echivalent plasarea boxele surround 27.5 metri distanță de poziția de ascultare!
Ca o regulă de degetul mare:
În cazul în care boxele surround sunt situate în apropiere de poziția dvs. de ascultare, ajusta întârzierea spate scurt (5-15ms).
În cazul în care boxele surround sunt situate departe de poziția dvs. de ascultare (20-30ft), reglați întârzierea spate lung (15-35ms).
Notă: Este important să se stabilească întârzierea corect, astfel încât sincronizare de timp corespunzătoare apare.
Ajustări audio de nivel
Calibrare nivel dintre toate difuzoarele într-un sistem 5.1 este unul dintre cei mai importanți parametri reglabili. Mulți oameni au tendința de a stimula nivelele spate difuzoarelor prea mari în raport cu fronturile și canale centru. Acest lucru, uneori tinde să supraaccentuarea canalele din spate care rezultă într-un domeniu de surround nefiresc, care este ușor de localizat de către ureche. Peste subliniind un anumit nivel de canalul de sunet se va diminua echilibru în sistem. Procedând astfel, subminează ceea ce inginerie de înregistrare destinat amestecul să sune ca pentru CD-ul filmului și / sau muzică.
Vă recomandăm următoarea procedură de calibrare nivel adecvat de dvs. Sistem 5.1 surround:
Selectați o poziție comună ascultare.
Reglați volumul principal al receptorului / preamplificator la un nivel comun de ascultare v-ați obișnuit să (să zicem 75dB).
Inițiați Receiver / tonul de test Preamp.
Permiteți ton de test pentru a matura fiecare difuzor în sistemul dumneavoastră.
Reglați nivelul volumului pentru fiecare canal pana cand suna similar în volum. Este de preferat să utilizați o metru SPL (C-cântărire, răspuns rapid) pentru o precizie mai mare.
Acesta este primul pas în calibrarea nivelurile sonore ale dvs. 5.1. Vă rugăm să rețineți că aceste niveluri vor trebui să fie optimizat în funcție de înregistrarea sursă și / sau sistem de surround.
De exemplu: Unele înregistrări pot stimula canalele din spate 1-3dB mai mari decât nominală, datorită metodelor de amestecare sărace sau factorul de wow deliberată. În cazul în care nivelurile de spate suna prea tare atunci când vizionați un film sau ascultați un mix 5.1/6.1/7.1 audio, scădea pur și simplu le până când acestea suna relativ echilibrată la canalele frontale și centrale.
Vă recomandăm achiziționarea unei multi-canal set-up de disc, cum ar fi cel de la Avia, Sound & Vision, sau DTS. Acesta vă va ajuta să calibra nivelurile de ascultare de difuzoare și subwoofer, după cum se mătură frecvențe 20Hz la 20kHz pentru toate canalele.
Dacă nu aveți încredere în urechile voastre, ați putea dori să achiziționați un Radio Shack metru SPL. La operarea tonul de test de receptorul / preamplificator, calibra nivelurile de volum în termen de 1 dB relativ la fiecare canal. Țineți aparatul astfel încât microfonul este îndreptat spre tavan și poziția microfonului cât mai aproape nivelul urechii, ca posibil (la fața locului dulce ascultare) atunci când rulează acest test.
Notă: Asigurați-vă că ați setat scara la "C-ponderat" pe metru SPL ca aceasta coincide strâns un apartament curbă de răspuns de frecvență de-a lungul benzii sonore.
Avansuri tehnic Update: Cele mai multe receptoare / prelucrători construite din 2003-2004 a vă permite să configurați distanța de la doar fiecare difuzor pentru a asculta pozitia. Calculele matematice de intarziere sunt apoi efectuate de către receptor sau de preprocesor, astfel economisind o mulțime de dureri de cap și de timp. asigurați-vă că pentru a calcualte distantele la un punct singular, la fața locului dulce, chiar daca le-ati ascultat pozitiile de-a lungul camerei de ascultare.
Text tradus de google, preluat de pe audioholics
32ES6100
gigi43
Localitate: Baia Mare
Înapoi la Sunet
REVIEW
Samsung KU6072
PROMOTIE
Click aici pentru detalii!
