i would like to ask you how is possible to set Auto off when I watching movie from USB. When I watch normal TV, i can set it in Tools, but when I am watching movie from USB I don't see it this option.
Hi Kwell, indeed, there is no sleep timer in tools menu when playing from USB. Maybe you could try the set the "Auto protection timer" from System menu. I think, minimum is 2 hours, but it's something... Or there is some "hidden" button on remote? (worth to look for...)
Thank you for your advices. I just check if there is some sleep time button on TV remote, but didn't find anything. When I will be at home, I will try to set timer before swith to USB as essco said
